- Apr 15, 2006
- 22,633
- 20,525
- 113
- Location
- Sth Auck, NZ
- HSV VS Senator, VX Calais II L67
Finally making some decent progress. Oil pump primed, filter extension housing on and a new filter pre-filled with oil.
Then Got the PS and cooling lines sorted.
Then remembered I was waiting on rocker cover gaskets. 2 steps forward, one backwards!
Remove the rocker covers and fit gaskets. Used a little silastic on the seals so next time they come off the gaskets stay put.
And drained the old milkshake and gave her a fill of Penrite 15w-50 extra 10th full zinc oil.
Time to get the drinkers side buttoned up.
(****, what a **** photo )
Still missing the PCV clean air side hose. Was also missing the purge solenoid hose to TB but found it behind the air filter box.
Filled the cooling system with water, checked over all the connections and hooked up the battery. Still have no spark plugs in the motor and the DFI module is unplugged. Turned it over on the starter and the oil pressure light went out within 30 seconds.
Fitted a new set of Autolite 606 plugs gapped to .050" and turned it over again. Sounds like it has compression. By now it's starting to get dark and decided to clean up but then decided I wanted to make some noise. Found the ignition leads, took a bit of a guess and fitted em and plugged in the DFI module and we are ready to fire, wrapped some electrical tape around the PCV hose fitting on the LPG mixer to stop the vacuum leak. It fired almost straight away and stalled. Fired it up again with a few revs for about 10 seconds and let it settle to idle.
So it runs but it has a lifter tick. The tick is at the front of the motor on the passenger side on the cylinder head that had the heaps cut off the valve seats so I'm certain I've got way to much lifter pre-load and I didn't manage to find the shims I needed for the rockers so that will be the first thing to sort.
Still need to bleed the cooling system, I don't have a thermostat fitted as I had intended to run a cooling system flush first but I'm gonna fit one tomorrow.
As the engine warmed up and I gave it a few revs the lifter tick got less so it's not the end of the world.
I even did a moving picture show, with sound....
