Just had the Lovells fitted at the garage next to work. Ute now sits 20mm higher in the rear than before. Will this settle down and drop a tad over a few weeks - months? It looks odd because it sat level before. I fitted standard height coils but they are slightly heavier duty compared to factory.
Kinda make me want to replace the fronts now to level it up.
Found out today wagon rear socks are different to ute. Not sure the difference but different part number and different listing for KYB.
Could also be that they are new and not 25 years old. Did you see the pic, are my suspicions correct and they are indeed upside down? I wonder if that has caused it to be a little tall in the rear.Having them slightly heavier duty than standard, will cause the car to sit higher.....The difference I can't say.
It may settle a little over time, but don't expect it to be 20 MM lower.
