jdodd
Thanks for the info.
Seems my mates 5ltr VR has the 931 injectors from a VT - VY V8...
any issues with the 931 injectors in your mates vr 5ltr, what kind of setup is he running
the 931's flow a lot more then the standard injectors causing the engine to run rich right through the entire fuel map. if you adjusted the tune then it would be fine
931's operating pressure is rated at 3.5 bar, which may impact how well they work. i think you can run well over the rated operating pressure and it won't effect the spray quality and operation. but im not sure when you run below the rated pressure what effects it could have.
