Skylarking
- Feb 3, 2018
- 10,130
- 10,590
- 113
- Age
- 123
- Location
- Downunder
- Commodore Motorsport Edition
Such “black magic” is talked about all the time regarding extractors and negative pressure waved bouncing back to the intake to suck just that little bit more gas out of the cylinder and aid performance... Everyone accepts that without question but when it’s the same physics used on the intake side to tune positive waves arriving at the intake ports, there are doubtersThere was a thread about this not very long ago, I can't remember who it was that posted up a heap of info from a company that developed their own intake but kept the expansion chambers because they enhance performance as well as decreasing intake noise. They were sprouting black magic like reversion wave technology and pressure equalization in intake velocity.
Personally, I believe it's just for noise reduction. How a reverted pressure wave (as opposed to a reverted "sound" wave) can overcome intake velocity as well as get past the throttle body is beyond my comprehension. This website had dynographs proving performance increases over straight pipe too, but we all know dyno results can never be manipulated to show a desired outcome.
What I know from experience is that car manufacturers are cheap, sometimes real real cheap... and they play games...
As such, a straight or curved carry over pipe from an earlier model will always be cheaper to use than making a new injection mould for a complex shaped intake. So if they made it, there must be a strong reason and it must serve a purpose regardless of whether we understand it or consider it “black magic”.
Maybe that black magic is to make the car quiet so and optimise efficiency for the intake restriction that is the standard air filter. Maybe it’s simply to make it quiet to differentiate the refined cheaper models from the noisier performance models... who knows as what car makers use in their decision processes is where the real voodoo occurs... we are just their pin cushion dolls or fodder for their machine if you will
As to aesthetics of the WM, can’t any of the engine when the bonnet is closed, which is 99% of the time, so hardly worth the effort... Unless your the perspex panel with led fan type of PC owner
If OP wants power and noise, as mentioned, there are other better ways to accomplish such But doing so will devalue the WM in the longer term. At yhe end of the day the WM supposed to be a luxury car, it’s not a performance oriented and noisy machine
