Mangcaprice
- May 1, 2023
- 2
- 0
- 1
- Age
- 20
- Location
- Australia
- Wn caprice v
Hi I’m planning on installing a Dod delete kit myself I’ve looked through the forums and thru facebook and I can’t find the help I’m looking for.
Other than the dod delete kit (
and blocking off the oil relief valve in the sump is there anything else I should do l98 oil pump or stock pump? Should I block off the oil lines under the valley plate or will the o rings on the delete plate be strong enough? I know I need a cam and other supporting parts I’m just wondering about the dod delete
- Genuine GM Performance LS7 Lifters | Part #:12499225
- Genuine GM AC Delco Lifter Buckets Trays
- GM Valley Plate
- GM Valley Plate Gasket
- MLS Head Gaskets (Pair)
- Head Bolts Set (Pair)
