Wheel studs are held in tension by the wheel itself sitting between the hub and torqued up stud nuts. Thus the stud’s job is purely to hold the wheel hard up against the hub face itself. Sliding force across the hub face itself, and thus a cross the studs themselves will cause them to fail over time.
What stops the wheel from sliding along the hub face is the hub flange which engages with the big hole in the middle of the wheel itself. Surprisingly the flange at only 5 or so mm but is able to take all the sliding forces and make the whole shebang safe.
All,the spacers I’ve seen push the wheel away from the hub face so the the hub flange no longer locates the wheel and thus the studs take foxes they weren’t designed to handle. Rather unsafe.
So
@panhead,
@vc commodore or
@Forg, since you’ve seen MB, Porche or Volvo OEM provided wheel spaces, do these spacers engage with the hub flange in the same way as a normal wheel would? Do these OEM spacers also provide another wheel mating face with flange that the wheel then locates on? How thin/thick is the whole EOM spacer?
I suspect that the OEM spacers must be made of a quality steel as I suspect aluminium alloy would be to soft. Do you guys have any pictures of these OEM spacers?
Just curious as to how they look and mount
