Limiter issue
DrownInMilo
21
Vr statesman
Hey guys, have my vr stato that’s got a vt 5l a good old Limi bash the other day and discovered the limiter doesn’t appear to be there the thing just revved, anyone know if that’s cos I’m running a vr ecu? And if so is it possible to tune in a limiter
Deuce
Super Stock
'94 VR SS V8
Yes the limiter can be adjusted with tuning.
How far out did it rev for you? As those banana manifolds in stock form will naturally limit rpm potential.
Immortality
Staff member
Sth Auck, NZ
EOM rev limiter is a fuel cut, I think they are set at 5600rpm on the VN-VS motors?
If it went past that someone's probably played with the tune....and probably abused the crap out of it too.
Factory tune will also force an upshift from 1st to 2nd regardless where you have the shifter set. People alter these types of settings to do burnouts.
DrownInMilo
21
Vr statesman
The ecu is stock vr statesman auto ( I’ve put a getrag manual in it tho) the motor is out of a vt ss race car but I’ve swapped the vr throttle body and intake manifold on so it will work, I revved it to 6k 3 times in short bursts. When it had the vr motor still in it it had the limiter but doesn’t appear to with the vt one but I would’ve thought the limiter is governed by the ecu and putting an engine that may have been being used without one wouldn’t make a difference
Immortality
Staff member
Sth Auck, NZ
Did you change the memcal to suit the manual transmission?
DrownInMilo
21
Vr statesman
Nope but when it had the vr motor and the getrag it had no issues at all
Immortality
Staff member
Sth Auck, NZ
Was it originally a auto, earlier you said you fitted the Getrag?
A VR auto that is converted to manual is going to throw a engine check light when it can't see the auto and set a whole heap of fault codes unless the tune is altered to suit.
Either way, something isn't adding up.
Take the cover off the PCM and have a look at the memcal in it and tell us what the code is on the little silver sticker, if it still has the silver sticker.
gtrboyy
vt ss & lc gtr
How does speedo work?
v8 getrag have external vss & slip yoke has geared tooth on it... signal different to auto & it goes through ecu.
Only know as did vs s3 304/getrag in torrie with 3.9 gears...it easily smacked 5400 or whatever it was rev limiter when doing silly ****.
07GTS
Australia
VEGTS BUILT BLOWN E85
prob just thinks its in neutral all the time using the idle tables
