LLT to VF LFX engine swap requirements?
_R_J_K_
Zenki S14
Hmmm, I think the two LFX pictures I've posted are actually BCMs.
vywgn
1967 Holden HR Premier Wagon / 2015 VFII SV6 Sedan
You will need to source a VE LFX loom, just find 1 to suit your trans type
vywgn
1st and last link are the ecu, 2nd and 3rd are the bcm.
LachieKb
Nsw
VE SV6 Ute
Ah ok. But I will be able to reuse the ECU and sump from my LLT? Or source those from a VE LFX too?
vywgn
Will need ve lfx ecu and can use your sump
Fu Manchu
WA.
I’ll be another to confirm. You need the motor. You will be using your looms, sensors and ECM that is currently in the car.
All the advice so far is solid. Take it.
LachieKb
Nsw
VE SV6 Ute
So I won’t need to replace any electronics/ecu/ecm, just the engine itself, swap my LLT sump onto it, get LFX cats and headers, and use my LLT electronics? Or will I need the VE II ECU and loom as vywgn suggested?
The first engine I found fell through but I’ve found a couple others, but both from VFs, so I want to be sure if I need to get any other parts with it.
Fu Manchu
WA.
If you currently have an LLT, then you would already be driving a series 2 VE.
Fu Manchu
WA.
Wait. LLT is the intermediate series 1.5.
Fu Manchu
WA.
You should be rights just swap the motors over. Integrated headers etc so you’ll need the exhaust bits.
If you start swapping looms and ECM, you are going to enter a world of hurt. It could easily end up like rabbit hole of pain.
