LN3 Heater Core Bypass Help
Fu Manchu
WA.
The one I linked has two different sizes.
Fu Manchu
WA.
LS1 is two different sizes. Will that fit?
realaverage
30
WH Statesman
The one you linked is 30mm both ends. The LS1 isn’t big enough on the largest end. I’ll replug a bend into this current one instead.
Although it might still be dead, my mechanic reckons that the link shouldn’t cause any type of overheating?
Fu Manchu
WA.
Why not use two right angle brass barbs?
Fu Manchu
WA.
It would do because you get trapped air and restricted flow. Where that happens, you can bet something goes bad.
  • Like
Reactions: Lex
