If it's not modified than it's exactly the same as the V6 TB other than it's 5mm bigger internally.If l remember correctly, he has the v8 5 Litre throttle body on?
Is the tps the same?If it's not modified than it's exactly the same as the V6 TB other than it's 5mm bigger internally.
Not sure how good the auto electricians are near you but every time I have used one they are not God of car electricals. They know more than the average garage sure, on electrical gremlins but diagnosing intermittent issues is not an easy task even for someone with such skills. If it's a common issue they can sort it but when the problem comes and goes there is not magic tool that you run over the entire car that tells you every problem there is...... Yep the old ute has had some dodgy work done by PO's and I am getting to the stage where I have fixed most of the botched up work.It just might be time to bite the bullet and see a proper car sparky and get the issue diagnosed properly and fixed and pay $, surely it would be cheaper in the end, less stress, less flatbeds, less buying multiple sensors and less touching things that could make things worse.
Plenty of US vehicle models listed here and info on what Holden used.
https://en.m.wikipedia.org/wiki/Buick_V6_engine
