Just some food for thought @losh1971.
Heat is the enemy of electronics.
As such one must wonder whether mounting the DFI module to a cooling plate which is itself bolted to the idler pulley (next to the water pump) and head would provide a path for heat to flow from the engine to the DFI mounting plate. If such a heat path exists, then the question is whether the cooling effect provided by the wind caused by the accessory belt hitting the underside of the plate is enough to account for such a heat path in an older hotter running engine. The question of whether oily muck on the underside of the DFI mounting plate can also act as an insulator making cooling all the more of a problem could also be an issue.
As is, nothing really required the DFI to be mounted where it is and it can be relocated to a cooler location away from oiling issues... This may just be the reason someone can justify an OTR CAI Or, if original aesthetics are preferred, a little fan can be made and mounted on the idler pulley to kick up a bit more of a wind storm to improve on the cooling ability of the DFI mounting plate or cold air brought in via some plumbing. Keeping the underside of the DFI mounting plate clean also couldn’t hurt. Heck, a good welder can even increase the size of the cooling ribs on the underside of the plate if there is space (keeping in mind the need for bolt access).
Otherwise if heat isn’t the real cause of the problems experienced by DFI modules, it may be vibration is the culprit in which case relocation may be the better approach.
Don’t have a V? series V6 but from what I’ve read it’s a common problem...Makes you wonder why alot more people aren't experiencing the same issue?
What makes me wonder is how in older cars with points driven distributers, a single oil filled coil lasted for decades with minimal issues. The one coils magnetic field was created and collapsed to service all spark plugs within the engine. The more modern V? series V6 in comparison has one coil for two spark plugs and doesn't seem to last as long or provides some feedback to the DFI and one or the other or both die....
cheap mans contact cleanerpulling the DFI plug and putting it back on might have had the same result....
Yeah and that is something I was thinking I will do next weekend. I have contact cleaner at home in the shed. I did that with my ALDL plug and put a couple of sprays of WD40 and pushed in the ALDL cable a few times to work it in. Certainly helped when that was having problems connecting with my old laptop.cheap mans contact cleaner
