losh1971
- Jan 17, 2010
- 22,633
- 22,436
- 113
- Location
- North Tas
- VE Series I SS Ute
Went to the self serve wreckers this arvo in an attempt to find a decent wiper plenum. Seems like they are all gonna have some sort of cracking, even the really well looked after VS' had some cracks. Ended up staring to remove one off a VS and the bloke wanted me to get one off a more stripped out vehicle. Damn I had already spent 20 mins working on getting the plenum off. Went to another VR and started but couldn't get the wipers off and had to give up as it was getting close to closing time.
With like 20mins before closing I raced around trying to find a passenger window strip. I had a look at few but the rubbers were all really hard and most had a tear at the rear most edge of the rubber seal. Found an ok one and then realised I have just about run out of time and had to give up. I did however work out why mine was cocking up at the rear, it was because the retainer screw was missing. I fitted a new screw and it sits down pretty well now. While I was there I had a look at the VS and paid for a dash piece that I can pull out tomorrow. Mine was giving me problems with the radio facia dropping down a few mm because the slots the facia slide into are damaged on mine.
So in the end I managed little but did work out a couple of things so wasn't a total loss.
When I got back I had a look at the small rear window moulding and panel and it's pretty damaged. I have taken it off and need to do some repairs on it to get it looking good. I could try to buy another panel but I'm thinking I can repair mine to look as good as a replacement. What's happened is a previous owner has cracked it in two places where it screws to the body. I need to make an elbow and glue it in with JB Weld so it can be screwed on down by the door window trim and I also need JB Weld a washer where it has broken away on one of the screw holes. Then I need to prime and repaint the black areas as the white is ok as I already painted a couple of months ago.
