Plus one to blowing up airboxes with LPG.
My car has destroyed 3 in the last 2 months.
Put it down to too much vacumn developing in the intake manifold and airbox. sucking LPG out of the mixer through the pin hole in the throttlebody.
As with the pod on there and no restriction, It backfires rarely.
and it spins the wheels if i plant it in 2nd.
I had only just put in a VR ex cop motor into my VN calais before i left for NZ for work. Will start tuning the LPG when i get back to Adelaide on the 21st. Hopefully the battery hasn't gone flat on it.
Guessing its just the Sensitivity control on the convertor, as the high flow gas adjustment seams to be pretty right.
So, I am on the Positive Side OF LPG. If set up right its a better fuel then petrol, due to the higher octane rating. you can bump up the compression abit more and give the timing a remap with a new chip and have a kick ass setup. As long as the mixer isn't too small to pose a restriction to flow into the throttle body. The one that was on mine was, but i have machined out the mixer to solve that problem.
Talk to a few places to get ideas on how they would setup LPG for your particular model. Tell them what your after, performance or economy and listen to their ideas for your system.
But set a base set of questions to ask each place so you can work out who will install a system that suits your needs.
Best way to do it, as there are some dodgy places and some good places.
But definitely LPG is worth it.
