lol @ commsirac
On a system thats just slapped together, sure LPG Sucks.
But in a vehicle where the Engine and ECU are setup in conjunction with a decent LPG system. To take advantage of that higher octane rating. Well lets face it LPG is in a higher league then most petrol systems.
Common Misconceptions
LPG cars are no good for turbocharging - Incorrect. In actual fact they tend to be better because of the interherent properties of LPG.
LPG cars are harder on engines - Correct, atleast generally speaking. LPG cars do favour certain types of oils given the 'dry' nature of LPG itself. An incorrectly tuned LPG car will kill an engine. But then again an incorrectly tuned Petrol car will kill an engine too.
LPG is no good for performance - COMPLETELY INCORRECT. You've only got to take the number of turbo charged XF falcons running 250 crossflows, LPG and BIG turbos as proof. There are even a number of LPG VL turbos happening these days.. It's all about the tuning and the configuration.
BBQ gas is better than pump LPG - Correct. BBQ gas has a higher propane level and hence has a higher energy rating than typical pump LPG. Pump LPG tends to have a higher propane level during the winter months because it's colder and the propane prevents the LPG freezing in the lines when it's cold. If you do get a chance to fill up on BBQ gas, GO for it. You'll get more performance out of your car.
Now on that last comment, there is a LPG "service station" joint just near Edinburgh Air Force Base here in Adelaide, that sells LPG with a Higher Propane Level than u will find at any servo.
I fill up both my V6 ant 5.7lt there every week and the 5.7lt is running a straight gas manifold system and makes a **** load more power then it ever did on Petrol.
Would i go back to using petrol. . . .with my experience on my own Properly Tuned vehicles . . . Hell no!
But as The common saying goes... Opinions are like ass holes, everyone has one....
So make your own "Informed Choice" from your own research guys.
LPG Explained... An Introduction to LPG
http://www.performancelpg.com/viewtopic.php?t=2
LPG Injection - whats it about.
http://www.performancelpg.com/viewtopic.php?t=14
LPG as Diesel Replacement
http://www.performancelpg.com/viewtopic.php?t=7
