commsirac
Banned
- Aug 31, 2007
- 1,183
- 20
- 0
- Website
- www.google.com
- vx
BBQ gas is better than pump LPG - Correct. BBQ gas has a higher propane level and hence has a higher energy rating than typical pump LPG. Pump LPG tends to have a higher propane level during the winter months because it's colder and the propane prevents the LPG freezing in the lines when it's cold. If you do get a chance to fill up on BBQ gas, GO for it. You'll get more performance out of your car.
Good points in your post ^ earcruiser, but this part is not quite right.
Propane has a higher octane rating, not a higher energy rating. The higher octane rating (RON) is really only a consideration if building a motor with compression ratio of > 11:1 to ensure that the RON is always high enough, this cant be guaranteed on pump lpg mix, but even a 50/50 mix of butane/propane has a RON that exceeds premium unleaded anyway.
So more power can be developed out of propane if the motor is rebuilt and slightly more if timing adjustments are made in conventional motors.
Otherwise, the car will travel less distance on a litre of propane than a litre of butane/propane mix.
Butane wont freeze in the lines of the car, its freezing point is way lower than anything experienced in this country. Higher levels of propane may be added due to the butane being less likely to vaporise easily at low temperature, though I wasnt aware this was industry practice in the winter months.
This is one reason why domestic supplies of gas have no or low butane as in cold conditions there is not enough vaporisation pressure from the butane to get it out of the tank and the resulting change in mixture that occurs can play havoc with the CO emissions that are produced inside the home.
