LS3 CAM 224/228 OR 224/232 CHOICE
HotdogNo1
QLD
VF SSv Redline A6 W407
Was able to purchase an original w407 camshaft from walkinshaw mainly because I live around 1500km from any authorized walkinshaw workshop
W407 or W557 is the Same cam
I haven't opened the cam pack yet.
But Revster has the info
W407 cam
Duration @ 050 222 in 228 ex
LSA 116
Lift .585 int .591 ex
.05
69
vic
vl v8 commodore
Cam upgrade what else will I need?
I think I’m ready to cam my car?
Keeping stock converter, Ls3 heads, lifters
what's included in package for $3600
Manley dual row valve spring with upgraded fitting hardware (pending availability at time of order)
Rollmaster Single row timing chain kit.
Genuine (GM) Gaskets
Custom tune to suit.
VCM Camshaft. Not required
I’m Supplying w407 camshaft from Walkinshaw 222 228@116LSA
All labour involved with fitting required components
Other recommendations
LS Rocker Trunnion upgrade kit $380.00
https://vcmstore.com.au/products/ls-rocker-trunnion-upgrade-kit
New spark plugs $130 (NGK TR6)
Engine oil service (Mobile 1) $280
Replace drive belts if needed
Before and after dyno graphs
Total price about $4500
hot dog do you have the valve lift specs and advertised duration of the w407 cam, you should have a cam card or sheet with the specs in the cam box if you could post a picture of this spec sheet would be great, also if your installing a 3 bolt cam you might want to buy parts to convert it so your engines using the correct chain tensioner and parts for the 3 bolt cam for long term reliability as your engine will have a single bolt cam set up, its not expensive so everything matches up, thanks mate
HotdogNo1
QLD
Thanks .05 I've checked inside the cam box and all I can find is a sticker on the side of the box. Will ring walkinshaw about the card and if it's a 3 bolts cam or not.
HotdogNo1
QLD
I checked the cam this morning and it's a 3 bolt cam. Walkinshaw have been very good to me So I'm not willing to post the specs card sorry.
White Swan
NSW
VFII SS
Why not, Walkinshaw wouldn't provide the spec sheet if it's that big a secret?
I'd guess it's a tried and trusted grind that Walkinshaw would have rebadged like everything else they sell.
Anyway Wiki Leaks will eventually release it to the world.
MrBags
45
VE SSV Z SERIES
I love me some top secret cam specs. :D
MrBags
45
VE SSV Z SERIES
I would think this is an incredibly safe bet.
07GTS
Australia
VEGTS BUILT BLOWN E85
love it how the base circle to 1.27mm lift is so secrete... but it prob spends more time there then all other lifts
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
