Definitely not the tuner preference he would have much preferred a turbo set up. I didn't want the heat soak issues and most kits for the alloytec are mounted under the car and where I live they would not have lasted long and the belt driven supercharger technology has come a long way thanks to capa performance and procharger. My intake charge is usually below 45 degrees and stays the same, easy to intercool. Once I build my next engine it will be running 19psi and the power curve is very linear and no boost spikes, very predictable power which makes it a lot of fun in corners
