The VE Steering Angle Sensor fits perfectly!!!
This has to be the steering angle sensor Holden used in the AWD Adventras with Electronic Stability Program. I also believe they used it in 2006 VZ HSVs with ESP. So it fits, but is there a mechanism in the VZ clock spring to turn the Steering Angle Sensor?
After messing with it for 20 minutes, there is! There is a single tang next to a tab that slots into a white collar in the base. Orient the Steering Angle Sensor to engage this tang.
And voila! A VZ clockspring with a Steering Angle Sensor!
I still need to get the connector from the guy I bought it from, and it will require some wiring to make it work. I have to bring the CAN Network in and out of the sensor and provide some power and ground, but what does this mean?
- It means I will be able to use a VE Commodore OS in my E38 computer, which means running a 6L80E transmission will be no problem!
- It means that in the Crewman, I will be able to use a VE Commodore ABS module
- It means the Crewman will have an Electronic Stability Program, or what we call Stabilitrak
- It means I will have an Engine Oil Temp Sensor readout, a Trans Temp Sensor readout, Displacement on Demand, and Variable Valve Timing
This is a huge win and I am so excited to start getting the Crewman wiring together so I can make all this happen!
