PWR auto trans cooler fitted.
Little update.
Just fitted a PWR automatic trans cooler kit and it was so easy.
I've had it sitting on the shelf since before summer and only just got around to fitting it.
Hardest part was separating the quick connect from the passenger side tranny steel line using the tool supplied in the kit.
The kits come stickered for VY1&2 but you just flip the cooler to face the drivers side of the car in a VZ, everything else is the same.
Here are some pics.
First 3 shown in situ bolted to factory holes already in rad support panel.
Also showing position of DUS intake IAT sensor .
Top radiator tranny connection with tail fitted then with hose connected.
The position of the quick disconnect that needs to be removed, the R one in the pic
Finally a shot of a new badge I fitted to the front grille, not sure whether I like it or not.
Cheers. SW.
