My Whipple Blown VT Senator Signature 220i
Dan VS 231
Perth W.A.
VZ Senator
GOTMYN
Stab it and Steer...
Mornington, Vic
Whippled 5.7, VE SV6, GU Patrol 3.0DI
Awesome work with the Sig and its a 5L too. Dream combo imo. I think maybe one of those Harrop diff covers could be a good idea when you change the diff gear around. Ive heard they are good for tramp issues plus have a higher capacity to keep it all cooler in there.
Edit: Here we go, found a link; 99-ACVR6824-00
Cheers Mate,
Yeh, it's a Holden motor, But 5.7 Stroker :)))
Those diff covers do look the goods, see how I'm going 4 cash when I get the diff done :).
I fitted some new shocks today, so see how it goes, I've had a drama with belts climbing over the Crank Pulley at high rpm, so I have spaced the alternator out 2mm to see how that goes.
I'm yet to drive it after the rear end fix......Shower & dinner, then maybe a cruise somewhere.......
GOTMYN
Mornington, Vic
Hmmmmmm,
this thing is still shuddering from the rear :-(
Checked tyre pressure, and set them at 28psi,
Shocks=NEW
K-Frame Bush's=NEW
Tailshaft=NEW
WTF is it??
Maybe the CV's in the drive shafts?
Diff is not noisy, so it's not that :-(
Vt_vic
perth,Western Australia
carless for now
go the full twin 3 exhaust a friend of mine did that to his vortech vnss only a 5l but made good power and torque over the stock system
GOTMYN
Mornington, Vic
Already have Twin 3" Mate, Cheers for the heads up :)
GOTMYN
Mornington, Vic
How bad is the shuddering? I've had a couple of VT-VX with the wrong/worn out oil in the diff and the LSD chatters.
It's enough to know it's there, doesn't feel like it's going to break something, but is very annoying, plus, it's worse one minute, and OK the next????
I don't like driving a car like this..... It is much worse now that the Nolathane Bush's and harder shocks are in :-(
I really want to get it sorted so the car can go for it's Engineers Cirtificate...................
WogBoyz
435rkw/590rwhp
Cairns, Qld
08 VE SSV M6 Ute
should take it to a suspension place to get it all checked out, was it doing it before the charger went on?
GOTMYN
Mornington, Vic
It did do it, but only at full noise and as it shifted to 2nd.......for half a second or so.............
Now it is any time you ask for a little bit of torque ................................
