This guy is a scammer and a rip off.
Here are a number of possible causes. This may explain the low oil pressure.
Failure of the crankshaft seal would led to oil escaping the engine, if that is so this is a possible reason for your problem. Get your hands on the bearing shells ior check all of them now, if the pair of bearing shells nearest to the seal show symptoms of seizure it will have a bronze colour to it, this is due to the oil film rupturing as a result of loss of oil pressure. The other two bearing shell pairs will just be shiny in colour, this is a sign of oil starvation. Also the rear bearing shells might have a foreign particle trapped between the bearing back and its housing which will lead to a raised area on the shell, equals stuffed bearing. Another one is poor engine tuning will cause excessive loads on the engine components.
Good luck mate
