Description:
FORD FALCON AU BA BF FG XR6 XR8 TERRITORY & MORE
HOLD COMMODORE VT VX VY 5.7L LS1 GEN3 0BD1 CORVETTE
LIVE DATA READS & CLEARS DOMESTIC & IMPORTED FORD CODES
ENGINE LIVE DATA. ABS AIRBAG DIAGNOSTIC SYSTEMS OBD1
A Scan tool that Will Read Australian FORD and HOLDEN
AU - BA - BF - FG
VT - VX - VY - VZ - VE
This Scan tool is not only for OBD2
it has the FORD and Holden software codes loaded.
It reads AUSSIE FALCON and COMMODORE when others will not.
If you have the following models you can check your ENGINE - AIRBAG - ABS systems [note. will not read AUTO TRANS before BF at this time].
AU all series 6cyl & v8 XR6 & XR8 ENGINE, ABS, AIRBAG System Codes.
BA all series 6cyl & v8 XR6 & XR8 ENGINE [live data via Obd2 function] ABS, AIRBAG System Codes.
BF all series have full Obd2 compliance, ENGINE [live data via Obd2 function] ABS, AIRBAG, AUTO System Codes
This Scanner is also designed for GM {American based} so it works on the following COMMODORES.
VT - 5.7L LS1 - Engine live data, ABS, Airbag Systems (not V6)
VX - 5.7L LS1 - Engine live Data, ABS, Airbag Systems (not V6)
VY - 5.7L - LS1 - Engine live data, ABS, Airbag Systems (not V6)
also
VZ - V6 & V8
VE - V6 & V8
via the OBD2 Program.
This will clear Fault Codes from Engine, ABS, Airbag System & Codes logged from - BCM - ENGINE Electronics etc.
Live Data on the VE shows the following -
Amount of Diagnostic Trouble Codes.
Fuel System 1 status.
Fuel System 2 status.
Calculated Load Value. %
Engine coolant Tempersture. C
Short Term Fuel Trim - Bank 1.
Long Term Fuel Trim - Bank 1.
Short Term Fuel Trim - Bank 2.
Long Term Fuel Trim - Bank 2.
Engine RPM.
Vehicle Speed Sensor. [kph]
Ignition Timing Spark Advance.
Intake Air Temp. C
Mass Air Flow Sensor [g/s].
Absolute Throttle Position %
O2 Sensor Output Voltage. B1S2
O2 Sensor Output Voltage. B2S2
Protocol. - EOBD - OBDSUP.
Time Since Engine Start.
Commanded Evaporative Purge.
Fuel Level Input %.
No of Warm-ups Since DTC cleared.
Distance Since DTC Cleared. [kms].
Barometric Pressure.
Equivalence Ratio [wide range O2S] [ B1S1]
O2 Sensor Current [wide range O2S] [B1S1}
Equivalence Ratio [ wide range O2S] [B2S1]
O2 Sensor Current [wide range O2S] [B2S1]
Catalyst Temp Bank 1 Sensor 1.
Catalyst Temp Bank 2 Sensor 1.
Control Module Voltage.
Absolute Load Value. %
Ambient Air Temp. C
Absolute Throttle Position B.
Accelerator Pedal Position D.
Accelerator Pedal Position E.
Commanded Throttle Actuator Control
TheVZ & VE has MISFIRE MONITOR so the scanner will tell you which Cylinder has an Electrical problem.
Over 7000 Fault Codes.
the VT VX VY have the following live data
Fuel system open/closed loop.
Coolant Temp deg C.
Short term fuel trim %.
Long term fuel trim %.
MAP InHg.
RPM.
Vehicle speed. Kph.
Spark advance.
IAT deg C.
Absolute TPS %.
All O2 Sensors.
Calculated Load.
Lamda readings.
Memory/ battery backup.
ALSO READS.
Misfire Monitor.
Fuel System Monitor.
Comphrensive components Monitor.
Heated Catalyst Monitor.
Catalyst Monitor.
Evap. System Monitor.
Sec. Air System.
A/C Refrig. Monitor.
O2 Sensor Monitor.
O2 Sensor Heater.
EGR System Monitor.
OBD2 Protocol Display.
FEATURES.
Works with all 1996 & later USA, European & Asian vehicles.
Suitable on Australian vehicles from 1999. [VARIES ON MODELS & MANUFACTURERS}
Reads & clears Generic OBD2 Trouble Codes.
Reads & clears Selected OBD2 Manufacturer Specific Codes.
Turns off CHECK ENGINE light [MIL]
Views FREEZE FRAME data.
Performs MODULES PRESENT TEST.
Reads PCM LIVE DATA STREAM.
Displays LIVE O2 Sensor Test data.
Displays Monitor & I/M Readiness Status. [emissions] & Misfire Monitor.
Retrieves VEHICLE INFORMATION NUMBER. [ VIN]
C.A.N BUS [controller area network] high & low capability.
Built in DTC library.
Upgradeable via USB port.
Reads Codes for POWER TRAIN inc. CHASSIS, BODY, & NETWORK. over 7000 codes. [depending on vehicle].
ABLE TO READ MORE OBD2 COMPLIANT VEHICLES THAN OTHER SCANNERS.
HOLDEN. FORD. MITSUBISHI. HONDA. SUBARU. KIA. DAEWOO. PROTON. TOYOTA. NISSAN. JAGUAR. MERCEDES. RENAULT. JEEP. CHRYSLER. BMW. PEUGEOT. VW. AUDI. ISUZU. HYUNDAI. MAZDA. RANGE ROVER...via OBD2 program
EASY TO USE, SIMPLE YES/NO FROM MENU.
PLEASE NOTE... Not all vehicles have all of these features, and the operation of the scanner relies totally on the on-board software of the VEHICLE.
Due to variations in compliance in AUSTRALIAN vehicle years, it is not possible to supply a list of compatibility here.
CONTACT US FOR MORE INFO. BUT PLEASE SUPPLY MAKE, MODEL, BUILD DATE & ENGINE TYPE. OR WE CANNOT RESPOND......
Please see the feedback from our Customers on Ebay
LIVE DATA. WATCH THE READOUTS AS YOU DRIVE.
All postage has been insured, so never have to worry about lost mail.
