I've had 2 new radiators since 2013. I put a 3rd one in last Jan. I stuffed the second one up. I can repair it. Paid $185.00 for the 1st one. 2nd one $230.00 2018. 3rd one $80.00 of ebay Jan 2023.This morning went to examine the radiator, the red oil still oozing out. Looking into the gap between the radiator and the front bit where the external transmission cooler is attached, the lower tray is quite wet. Therefore, I can confirm the fluid is leaking out of the bottom of the radiator. The transmission cooler pipes are submersed in the two vertical coolant tubes on both side of the radiator. The inlet cooler goes into the right top and comes out the bottom. An external cooler pipe carries the fluid to the left bottom vertical coolant tube. The cooler fluid than comes out of the top and to be carried to the external cooler at the front. The cooler fluid finally comes out of the external cooler and returns back to the transmission box. It really took me a while to figure out the design by Holden.
One of the cooler tubes inside the radiator is leaking and the horizontal tubes carrying the coolant between the two vertical tubes are also leaking as well, which results in oil leaking out to the bottom of the radiator. I will have to replace the radiator to resolve the problem. Any suggestion about which radiator to buy. I have gone through a couple of them on eBay. the cheaper one is around $180 but the more expansive one is $450. Any suggestion will be appreciated.
