Oil warning
Teddy LS1
Warnbro
VY Berlina
Hey I need some help. I just recently rebuilt the bottom end in my LS1 VY Berlina. Since the rebuild my check oil warning keeps beeping at me. First I thought it was the oil pressure switch. I replaced it, no change. Then I thought perhaps too much oil, that seemed to help it but now my problem has changed. It drives and runs beautifully. But at idol, it beeps check oil. If I raise reves to just over 1000 it goes away. When they drop to 980 or so it beeps again. Never comes on whilst driving. Any ideas
lout
60
Langwarrin Victoria
sounds like low oil pressure
07GTS
Australia
VEGTS BUILT BLOWN E85
sure the oring on the pickup pipe went in right to the pump inlet and didnt pinch and it was the correct oring ? LS1 shows oil pressure on the data so u could see what it is reading make sure its good
Teddy LS1
Warnbro
VY Berlina
Yeah oring was correct and I'm hopeful it went in correctly. No real way to tell now. What should my oil pressure be. It only seems to drop it idol. Before it was constant. I have no other signs of a bad oil pump. It seems to want to come on when it's parked on a hill or when swoshback from reversing and sudden braking.
Ginger Beer
Dunnydoore
What does it show up as?
My scan tool has nothing IRT oil pressure
I was of the impression they only have idiot lights and you need a dedicated oil pressure gauge
To the OP, what oil pump you running?
Teddy LS1
Warnbro
VY Berlina
I think I will truely cry if I have to rip the engine out again. It will be the third time this year. There is no way to check the pickup on this damn b*#+h with the stupid sump setup with engine still in
Teddy LS1
Warnbro
VY Berlina
Don't have a scan tool on me. Waiting to see a mate over the weekend. Just original standard oil pump. She idols at around 980rpm and that seems to set it off. Doesn't take much to stop it. Just a feather foot for about 5 seconds to just over 1000rpm. Could it be air
lout
60
Langwarrin Victoria
when you say rebuilt bottom end
do you mean machined crank and oversize bearings and new oil pump
Teddy LS1
Warnbro
VY Berlina
Crank and bearings not pump. And polished caps
