Airbox/filter setup is probably a bit more relevant on turbocharged engines. Unless oem airbox is very restrictive the engine cant suck in more air than it needs. I think the main advantage of otr cai is cooler air and more of it.
I don't think it's performance related Ron and solely about dampening induction noise. The Helmholtz addition isn't kind on the eye and would certainly look better without it. There used to be some factory like aftermarket smooth plastic MAF pipes, but I haven't seen any advertised for a few years.Yes. That's how I found out about it. Came across sv black article and spotted it. What's your view on helmholtz chambers on this one. Do you think the only purpose is to keep the noise down ?
That's right and many overlook this. The engine can only consume x amount of air depending on it's mechanical properties. Bigger air boxes, throttle bodies and manifolds do nothing when it's already consuming it's maximum of air. Ideally, the MAP reading should be at atmospheric pressure at full throttle and maximum horsepower. If the MAP pressure rises nearing maximum horsepower, the engine's intake restrictive somewhere between the air box and intake port. The LFX (SV6) engine gets a bit of pressure rise at 6000rpm I've noticed and could make a couple more with intake tidied up.And as for intake volume of air, the throttle body size, and its feed pipe that is the main restriction, then it's how the heads flow in and out
Sorry, not with you?
