Overheating - odd symptoms
RaptorBenn
Charleville, QLD
VX S '06 3.6L V6
I have a VZ Crewman ute with the 3.6l alloytec, and its losing coolant but there are no visible leaks.
syptoms
-Air bubbles coming out coolant filler cap
-Occasional rough idle but only on start and sometimes it will go away by itself or after restart
-losing coolant/ overheating (obviously)
had the radiator water pump and thermostat changed a while ago but no difference made, and the hoses are all good.
morphix
Cardiff, NSW
2004 VZ SV6 5-Speed Auto
syptoms
Have you checked the coolant reservoir? Any discharge/gunk on the coolant reservoir dipstick?
Could try placing cardboard under the car to see if any leaks show up by leaking onto the cardboard.
RaptorBenn
Charleville, QLD
VX S '06 3.6L V6
The reservoir is full but clean, and there's definitely no leaks.
petern64
60
Branxton NSW
vz ss 6lt , 2017 Mustang GT , 2021 BT50 SP
is the valley cover the same set up as an Ecotec?? because on the Ecotec the gasket deteriorates between the water jacket and exhaust port creating a path between the two ,,this happened to me ,just a thought !
ilusiv1
VZ crewman
Yeah bro I second the coolant cap, I had a VZ crewman that the temp kept climbing too, no leakage of any type, changed the cap all sweet.
