wortus
- Dec 2, 2009
- 1,885
- 22
- 38
- Location
- Sydney
- VY Series 2 25th Anniversary in Phantom Mica
Where is the bubbling sound coming from? If it's in the overflow bottle try a new cap or a friend had to bend the tabs on his to increase the grip against the radiator as coolant was escaping under pressure when hot but not sucking back in as the engine cooled.
If it's over heating at idle this may mean an air flow problem. Check that the fans are coming on or run your aircon at idle which will start at least one of the fans and see if it still happens.
Also check for oil in your radiator or coolant in your oil which indicates a problem with either your head gaskets or inlet manifold gaskets. The inlet manifold on my VY came loose and oil got into the radiator. It didn't overheat but I'd imagine it would eventually fail.
