I guess that is good as it will give me time to get it sorted. regards, Michael
The DTC means that the performance in V4 mode isn’t as expected which can indicate a mechanical issue is at play.
It could be nothing serious in which case it’s ok to drive around
or it could indicate a faulty LOM (faulty deactivation solenoids) in which case it’s ok to drive
or it could be dirty oil which results in the lifters (cam followers) not collapsing as expected which may or may not cause further damage. Or it could be some other mechanical issue that results in airflow through the motor not according to specs…
In my book, if it’s dirty oil which can be a cause of lifters not collapsing, such could possibly cause issues with the lifter rollers jamming which can then start to chew up cam lobes …. If that occurs, driving it may not be the greatest idea (unless you want an excuse to rebuild your engine).
So I’d not sit on it for a long time and would get your oil and this issue checked out sooner rather than later…
