I see there was no response to getting one thrown my way.
Thats OK I'll just have to buy it instead.
I do have a query though. I was reading the item description on your website and reminding myself of the prices for the 12mm + 12mm (incase that seems confusing to some readers, I mean the 12mm plennum spacer and the 12mm intake manifold spacer).
What is the better way to go? 12mm PLNM + 12mm INTAKE OR 25mm INTAKE without the PLENNUM spacer. Or both at 25. I realize and know about the bonnet clearance issue after 25mm But can work around it IF I decide to go for the 2 25's.
I am probably not going to be able to afford the 2 YET! but am wondering If I should just get 12mm Intake Spacer and maybe later the 12mm Plennum spacer. I could squeeze the cost of the 25mm Intake spacer but then would most likely not get the plennum spacer at all or at least not for quite some time. Sorry about the big essay and hope it's clear enough.
In regards to parts for testing, there is a possibility we could work something out I guess depending on what it was and how it was structured. I can't promising anything though. Best to draft something up in an email
As Jonah 101 has mentioned, we recommend a 12mm plenum spacer and a 25mm manifold insulator. Running a 25mm plenum spacer can reasonably dampen throttle response, however running a larger throttle body a revised tune does sort this out.
Without wanting to get into the whole yes/no argument, and not defending Sabbaths attitude here, I do agree with him that if you are selling a product, you kind of need to provide facts and figures that fit your particular product in the application you are advertising it as being suited to.
I'm assuming, and its only an assumption based on the statements by Sabbath, that no such facts or figures have been made available.
Even if this is only a few simple dyno charts with before and after figures on it, that would be useful for marketing purposes surely? If you feel it has more benefit in combination with other mods as well, then additional facts to show those improvements would be useful?
I assume when you design these parts to create various effects and improvements, you test them in some way? Perhaps those figures could be made available. I realise the theoretical parts can be proven, but I could redesign a plenum chamber to change the gas flow according to known and accepted theories, but make it worse in the attempt too (since of course I know nothing about it and have no means of testing any changes I make).
It would make good marketing sense to prove that your mods actually have the desired effect. Eventually word of mouth and endorsements just arent enough.
“Without wanting to get into the whole yes/no argument, and not defending Sabbaths attitude here, I do agree with him that if you are selling a product, you kind of need to provide facts and figures that fit your particular product in the application you are advertising it as being suited to.
Even if this is only a few simple dyno charts with before and after figures on it, that would be useful for marketing purposes surely? If you feel it has more benefit in combination with other mods as well, then additional facts to show those improvements would be useful?"
I definitely agree with the concept of asking questions if a person is genuinely interested in the concept/product. Anything else, and it's not really helpful and is a waste of time. In this case I MUCH prefer to be left alone
This aside if you read careful, I did supply a great deal of info, may not have been the answers that people liked but were answered the best I could. I could supply more info but where does it in?
“I assume when you design these parts to create various effects and improvements, you test them in some way?”
We do, even if it means working with others
“Perhaps those figures could be made available"
If we can justify releasing our IP, then definitely.
“I realise the theoretical parts can be proven, but I could redesign a plenum chamber to change the gas flow according to known and accepted theories, but make it worse in the attempt too (since of course I know nothing about it and have no means of testing any changes I make).”
Depending on the theory you apply and in what context, good practical results can come from theoretical ones if you know what you’re doing.
“It would make good marketing sense to prove that your mods actually have the desired effect. Eventually word of mouth and endorsements just arent enough.”
I do understand where you’re coming from; bear in mind though these products are about 5 years old now so there is a fair amount of impartial info out there from enthusiasts with these products, good bad indifferent. I think that this speaks more volumes.
In saying that though, there should be a write up in St33t Commodores over the coming months about a VS V6 resto build, presenting additional info on this and other products, which had been organised months ago. So despite the age of these engines/vehicles we’re still developing/testing them, with more parts to come in the next 6-12 months
