im still tryin to figure out what the SR20Vet is from... the Autech silvia s15? that is a NA but just scrapes through the power to weight ratio needed to be on the SEVS list.
or is it just not in a car eligable for compliance?
for everyone else, standard featurs of a 26 include;
4 bolt mains,
peened rods,
forged crank
center spark plug,
4 valve per cylinder,
3 angle cut seats,
8.5:1 comp in the top.
a coil pack for EACH cylinder,
twin over head cam,
nissans version of 'variable cam timing' which is pants and is usually ditched for solid timing gears.
ball bearing turbos,
3 throttle bodies,
i must say the little shims on top of the valves are a bit of a archillies heel though. it seems they need replacing every 50 thousand. but if thats the worst thing about this engine... well....yeah.
neermind, googled it;
The 2.0 L (1998 cc) SR20VET was the first turbocharged engine from Nissan with variable timing and lift control. It produces 280 PS (206 kW) @ 6400 rpm and 309 nm @ 3200 rpm.
It is used in the following vehicles:
Nissan X-Trail GT
sounds like a badass engine what are they worth?
4 bolt mains,
peened rods,
forged crank
center spark plug,
3 angle cut seats,
twin over head cam,
3 throttle bodies,
some pics of the vet i built
that would go fully sick
