detox_nath83
Another VL Driver
- Aug 6, 2005
- 2,160
- 6
- 0
- Age
- 40
- Location
- Queensland(Sunny Coast)
- VL Turbo Commo
the 2 barbs on the rocker cover are fed to the catch-can and then one hose(blue) from the catch can is fed to the PCV(Positive Crankcase Valve) valve on the plenum. so basically the can its just an inline filter so to speak.
(The catch-can i have is only a 2 port. so the 2 hoses from the rocker-cover are "T" Pieced into 1
Just so u know as well the hose from my cooler piping feeds the AAC valve (Auxiliary Air Control) this is Idle air control
As for the turbo drain just a oil/fuel safe hose man yeah with normal hose clamps(tridon/Repco) type as the drain is just gravity feed back to sump no pressure.
there are vids on you tube in how to rebuild a turbo.. straight forward man.. Nackerz did his one as well and was fine,
Actuator arm u need to be precise with the length as adjusting the length will change when it opens the flap.. (ppl shorten this rod to make more boost) without a boost controller.
did u try move it and check its length?
yes u can go with a 2.5 inch dump but would recommend a 3" to cat man as it will help the motor breath better and produce more power. and saves u spending more cash for a pipe to be made to 3" from 2.5 inch so u will be spending the money twice for a
dump pipe.
without intercooler man i would be carefull of pinging as the compressed air will be hot. expecially on a highcomp conversion.
As for intake put an air filter on man not mesh. mesh will not stop smaller debris getting in. and Fkn your motor over time.
If u run the 2.5 Zorst it will also be fine man. i did this for 6 months or so, with a 3" dump pipe to cat then 2.5 cat back with a 3" Turbo dump tip.
Dont worry about the questions man
thats what we r here for.
Goodluck man
