OK, finally sorted out the connection problems after faffing around for a couple of hours.
1. Pic 1 is the close-up of the lower screen corner and upper plenum cover. If the screen is leaking, it will probably be down in this corner behind the cover.
2. Pic 2 is a close-up of the top corner of the firewall, showing the glued seam between the firewall and the body shell. The bonding agent is extremely strong and flexible and is not likely to leak but if water accumulates in this pocket because of blocked drainage holes, it can find its way inside past the tiniest leak or gap in a grommet.
3..Pic 3 is the corner of the plenum cover, showing areas where leaves can accumulate to cause drainage probs. Make sure no leaves or other rubbish is accumulating either above or below the plelum cover.
4. Pic 4 is just another angle for pic 3.
In case you don't know, the plenum is the area below the windscreen where the wiper motor and wiper lingages are installed.
Good luck.
