figjam
Donating Member
- May 14, 2013
- 3,252
- 8,581
- 113
- Location
- Far Kurnell
- FJ
I have been paying attention to the comments, and I don’t want to get anyone offside here, but my comments in post #3 have come true, so, I am off to what may appear to be a bit of a ramble.
Ramble # 1 ……. All the comments that I have read here seem to me to be related to the front wheels, which undergo more operating variations and stresses than the rear wheels, which simplistically should be set at 0deg toe, and 0 deg camber, as they (theoretically) do not alter the steering of the car.
The Commodore rear end is ugly, compromised engineering, resulting in angle changes during normal operation, so, if the toe and camber were set at 0deg while static, how much does this vary during the up/down movement arc of the wheel.?
Ramble # 2……. This where my maths are questionable, so I could be way wrong here.
If the overall diameter of the tyre is 658mm, width is 245mm, and camber 12mm neg, I calculate that just over 4mm of tread has to be worn away on the inside of the tyre before the outside tread starts to wear. (Ignoring the toe, and sideways scrub effects .. I know this does not happen in real life.)
Ramble # 3 ….. A few years ago, the Monaro failed the annual NSW WRC, due to ‘uneven wear on the rear tyres’, being that the inside edges were worn. This led to a rather heated debate with the ‘inspector’ who failed it. I insisted that the tyres were not worn enough to warrant a fail.
But, he was right, and I was wrong ……… you can’t argue with little Adolf Hitlers.
Luckily, I had two identical brand new spares at home, on identical rims. I threw them in the boot, and took them to show him that the brand new tread also appeared to be worn, due to the asymmetrical pattern. But, he was still right, and I was still wrong. So, I fitted the new wheels, got the RWC, and bade him goodbye. Those rejected tyres proved to be good for RWC for a few more years, and a lot more kms.
As I now don’t have any matching spares for the wheels I have, I don’t want to be required to scrap good tyres on some officious b******s whim.
All this should be resolved within the next week when I get a wheel alignment (and replaced bits).
