delcowizzid
on holiday
Toe in doesn't wear the outer edge I don't know where you are getting that from
Then you look at how the geometery works....More negative camber, increases the TOE IN, yet toe wears tyres quicker than camber....So, how come, IRS equipped cars when lowered, accelerate inner edge wear, when TOE IN wears the outer edge, as shown by the link I put up?
Because negative camber doesn't necessarily increase toe, being slammed does which has the side effect of negative camber (and even then it depends on the car). Negative camber causes there to be far more pressure on the inner edge rather than the outer edge, so if there's heaps of pressure on the inner and none on the outer it's pretty obvious what will happen, and then if you add toe in to that.
For somebody who slagged off somebody else for using a computer screen to wheel align you seem to be relying a lot on general internet facts and links that don't cater to the scenario you're outlining. You're just seeing that A=B, and B=C, and saying that therefore A=C which isn't the case.
Yes, I agree, negative camber puts pressure on the inner edge, which would cause inner edge wear....Now check out the picture I posted up, taking note of the TOE IN picture and tell me how can TOE IN wear the inner edge, when it is plain, the outer edge of the tyre is taking most of the pressure.
Well, I can attest from experience as an IRS owner. I don't know how much more plainly I can say it. You can even see in camber diagram in the picture you posted that the inner edge touches the ground more. The diagrams you're using exist in a perfect world for demonstration where camber doesn't exist for the toe demonstration, it's to demonstrate a general concept. Dialling more toe-in isn't going to magically even out the pressure across the tyre face or give you more contact patch.
Raising and lowering a car isn't relevant when you make the claim that camber directly causes toe in. I can change the camber arms in my Silvia and give it massive camber at stock height and the toe won't change. Slam it with the stock arms and it will toe in massively.
Picture shows TOE IN has the weight on the outer edge
It is being claimed TOE IN scrubs the INNER EDGE
Please explain, because it goes against any sort of logic
