no point making your plenum look like a mangled whorebag do it properly and drop it into one pipe
or 2x throttle bodies at the front of the engine
WTF are you talking about?
Your going to need some sort of twin entry plenum with the cooler you have klampy is right twin in twin out you need to use all 4. The problem is if you go 2 into 1 your going have a mess of pipework and one length of pipework is going to be hell of a lot longer than the other. Ideally you want to keep the pipework as short as possible and same length for either side or as close as possible having the manifold as you tuner said is the best solution to the problem you have.
This is how we did my mates setup. basically we got 2 smaller identicle coolers cut off 2 end tanks flipped them around and modified the intake holes. they're mounted vertically and both coolers then welded together. This also increases the size of the core that actually get use in cooling creating a more effiecent cooler and directing airflow better (making greater use of cores crosssectional area).
They angle back slightly and towards the top also requried mount the radiator back and down a little and having a custom neck to bring it up the the highest point or original height if you prefer. the plenum uses 2 v6 throttle bodies with a custom sheet metal plenum to increase volume an direct airflow better.
You'll notice how short the piping is is giving you less loss in boost pressure and a small decrease in lag
Tommay doesn't look like a mangled whorebag to me and i'm sure it's better than anything you can weld together. My mate and i are welders by trade and do this **** all the time. Maybe other people can give their opinions on this setup and tell me how **** it looks
