lout
- May 13, 2006
- 5,567
- 4,276
- 113
- Age
- 60
- Location
- Langwarrin Victoria
- VXii Executive V6 , VYii Adventra LS1
once you have accepted that the ecu is not faulty
we need to look at the fuel trims and see what is causing the issue
O2 sensors are most likely reporting correctly
no more parts cannon
when you can access a decent scan tool
check some live data
if the coil dfi is faulty, that issue will still present now
all you have done is stop the ecu going into closed loop and changing fuel trims
