Yeah,Im not exactly sure what act it actually was,it mentions it on a sticker thats on the sun visor in my oldies HQ ute.The visors are from a later model though,maybe HX or HZ.I will have a look next time im there and post up what it says.Im not 100 % sure about the pollution gear setups on ford/holden six cylinder engines or older holden V8 stuff.I mainly owned 351 fords back then.. Whatever happened in 1977 or 76 or whenever it actually was,it killed performance and economy for both ford and holden on both the 6 cylinder and V8 engines, they both had a lot of trouble meeting the new emission regulations that were introduced.Heres a piece from a book that is some sort of official book on ford australia.
"The cross flow head on the 6 cylinder, burnt petrol more efficiently,thus achieving the boost in power.With this system, fuel was fed into the cylinders on one side ,while the exhaust manifold extracted the burnt gasses on the other.Unlike the de-emmissioned holdens,the XC did not run at higher temperatures.The hotter operation of the then HX holden resulted from an exhaust heated inlet manifold which was used to warm the car quickly and so reduce pollution.The new fords had water heated manifolds."
I remember comparing the older 308's to the 308's in the early commodores,these commodore V8's copped the full pollution gear,and they were never really that quick in standard form compared the the older 308's.Jeez you could easily get em going good though,Ive driven some bloody quick V8 commodores over the years.Im just glad of computers and engine management systems.We can now constantly have the perfect ignition timing to suit the engine load ,air temp ,fuel quality etc,computers are the best thing that has ever happened to the internal combustion engine. I now tune with the click of a mouse or keyboard instead of actually moving the dizzy or trying different carby jet sizes and having to make compromises with the ignition timing.The tune Ive just done on my VSV6 is way better than the standard one.Way more responsive,better fuel economy and no more laggy auto trans shift times.Years ago it would have taken a fair bit of work and expense to make the physical changes to things to get the same end result that Ive got with a few mouse clicks,way easier.
