so, would a "this part isnt going to be replaced list" be shorter to write out? =P
looking good.
all these little tips and tricks are helping alot.
good for learning how to spot and find rust, and to know what would go into repairing them.
keep it up.
Yeh, it probably would be easier to point out what isn't getting replaced rather than what is. Hopefully the outer shell isn't too bad when it comes time to do the body work.
So, big weekend on this car.
I got a step drill from work and drilled the holes for the body mount bolts where i repaired. Then i welded in some captive nuts. We got a body mount that was wrong for the car, but it actually came in handy as it had the captive nuts in it that i needed, so i drilled them out and welded them into the sections i made.
Then i proceeded to weld the sections in the car.
With that done, i welded in the floor section that i made last weekend.
I'm really happy with how this repair has come up, considering what i had to work with.
I forgot to organise some new sheetmetal this week so i couldn't do the other side. So i left that and moved on to the boot floor.
I started by welding in the R/H side floor section and drop down panel. I welded the boot in 1 section at a time as it's easier to stand on the garage floor and weld in each section that leaning over the car doing it in 1 go. Obviously i had to lean over the car to weld the last section in but i can deal with that
R/H section welded in.
That's where i got up to yesterday. So this morning, it was more of the same.
Centre section welded in.
Before i welded the last section in, i replaced the drop down panel.
The old rusty one.
All cut out. Another nasty repair was revealed on the outer 1/4 panel. Again, just a section pop riveted over the top. Again, this will get fixed when the body work gets done.
New section fitted.
L/H floor all drilled and cleaned ready for welding.
All welded in.
That's the boot floor done. Well, almost i still have to weld the fuel tank mounts in and the last body mounts just behind the rear wheels (i don't have those panels yet). That's where i finished up today.
Next is to repair the rear of the wheel arches.
