talljames
- Dec 21, 2008
- 23
- 0
- 0
- VT Acclaim Commodore V6
I am getting a light brown vapour/smoke coming out of my Holden 99 VT Acclaim centre air con vents. Here are the clues:
a) After driving for some time (more than 30min on the highway at 110 km/h) light brown smoke starts to come out of the centre console vents. At first slightly, then heavy.
b) The air con is on maximum cold and the weather is humid outside towards a hot day;
c) When the smoke appears the cooling is reduced. I was away on a trip in recent past and the air con just did not produce cold air anymore but in this case there was no smoke. So this suggests a air con problem. - New gas and leak check perhaps.
d) When it happens I turn off the air con and smoke/vapour still comes. Eventually, it stops and then I can turn the air con on again with maximum cool and it works fine again. - Maybe a blocked air con extraction pipe?
e) The air con is a replacement of the original - after market job.
f) I don't use the heater so I am thinking it is not the heater core.
Has anyone had an experience with this light brown smoke/vapour?
