Febey
- Jul 21, 2020
- 3
- 0
- 1
- Age
- 58
- Location
- Tasmania
- 2014 SV6 Storm wagon
I have a 2014 VF SV6 wagon with 75000 easy Klms, the car has had the steering recall performed and 3 recent wheel alignments to check a problem I have with the steering, the steering when in the neutral position (striaght line), has a vague feel, can wander and tram tracks, I purchased the car second hand at about 50,000 Klms, I am thinking it could be the front steering components worn, as I have just replaced the sway bar end linkages which were worn, but told this is a common fault with this model, I also understand the electric steering pump will adjust the wheels if it senses a deviation form the straight line path, which may be an input sensor, had the suspension checked but no luck
Has anybody else had any similar problems or can suggest any checks I can perform, I am new to the forum and hopefully presented the information correctly
Thanking you in advance
