MattComm
- Jul 4, 2018
- 1
- 0
- 1
- Age
- 30
- Location
- Melbourne
- VZ Executive
Hi there,
I've owned my 2006 Commodore Wagon for a little over a year now and it's been an absolute gem, but the radio/cd and lights have always acted a little weird, and gotten worse over time.
My first issue was that when I would keep the auto lights function ON, the backlight for the radio/cd display wouldn't turn off (all other interior lights did turn off) and caused my battery to go flat on multiple occasions. I figured out that if I turned the lights all the way OFF before switching the ignition OFF then the backlight would turn off and my battery stopped going flat and I could live with that for a while.
At my next scheduled service I asked them to check this out and they determined that my BCM was faulty and I'd eventually need a new one, which I couldn't afford to do at the time.
Over the next 6 months until my next service it started playing up even more, and eventually got to the stage where if I switched the ignition ON while the lights were in the OFF position, the radio/cd wouldn't work at all. But, if I switched the ignition ON while the lights were in the ON position, then the audio system would come on, but only play the last thing that I had it on, which was the cd player, but none of the controls would work except volume. So I couldn't change it to radio or skip song or eject cd or even turn it off, I just had to listen to the same cd over and over. Also, when I turned the lights OFF and then the ignition OFF, the cd would continue to play, so I had to switch the ignition back ON with the lights in the OFF position, which would then turn the audio off, then I could switch the ignition back OFF. (It's ok if I've lost you here)
Anyway, so I took it in for the a service today and had them replace the BCM, assuming (I guess wrongly) that would probably fix the issues, and getting the car back I tried switching the radio on and am still getting nothing. When I tried my trick of turning the ignition on with the lights on the radio system came on but asked me to put in the 4-digit pin, which I have, BUT none of the buttons on the system work so I can't put it in. So I've seemingly got nowhere.
Does anyone have any ideas what might be happening? I appreciate it if anyone made it this far!
Cheers!
Cheers!
