SV6 Not cranking, weird relay noise under bonnet.
dimsimnz
NZ
VEII SV6 Z SERIES
Have you tried running a scan tool to see if its thrown any codes?
I've misplaced my cheapo Holden Scan tool - so have just bought an ELM327 bluetooth OBDII reader... just figuring out how it works and the best software to use. I'll go and try it shortly.
dimsimnz
NZ
VEII SV6 Z SERIES
Ok, so this might be my shitty little ELM327 adapter or the software im (OBD Auto Doctor Free on Windows) using but i dont seem to be able to query or view the Engine Management Controller or DME or whatever its called.
I can see the Transmission and Fuel Pump but nothing else!
Also I can hear what I think is the fuel pump running in the rear somewhere when the ignition is on.
Heres what happens when i turn the key https://www.dropbox.com/s/8wcz5dl2ajj9qu6/IMG_2583.MOV?dl=0
I've visually checked all the fuses in the engine bay. Does anyone know where i should be checking to see if the ECU has power?
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
What comes up if you click on 'Trouble codes'?
dimsimnz
NZ
VEII SV6 Z SERIES
Pretty much the same - only able to select Trans and Fuel
lmoengnr
Donating Member
Sunbury Vic.
Know nothing about that software, can you find another program to try?
dimsimnz
NZ
VEII SV6 Z SERIES
I just opened the link to elm st. myself. Elm street doesn't cover ve.
Not sure where you got tha idea.. the link clearly shows it as being compatible
