Tonner Matt
- May 12, 2014
- 1,791
- 2,191
- 113
- Location
- Darwin
- VZ 1 Tonner LS1 M6
Have a good look around in the engine bay at the water pump, radiator & radiator hoses, heater hoses etc to see if you can spot any leaks.
Anywhere there has been a consistent coolant leak over time, you might be able to see a pinkish coloured stain with a white tinge to it.
If you can't see anything, then get the cooling system pressure tested.
Don't start throwing money away on parts until you identify the cause of the problem.
# See the attached pic for reference to leaking coolant stain
