Jonah 101
Undefined
- Jan 15, 2012
- 1,413
- 16
- 38
- Location
- Rotorua
- R32 Skyline
I'll be converting a series 2 v6 vr. I'm competent with all the mechanical stuff just after reading through he thread I'm still insure if the auto loom and ecu can be retained. I know the ecu will have to be remapped.
Would I be able to retain the Auto loom but use a manual ecu for a t5?
Yeah man.
ont the Tee shifter loom. just bridge the starter inhibit switch ( black and grey ). Wire the pink and green wires to the reverse switch. then run a inition on power source ( cig lighter ) to the vehicle speed sensor, a earth and run a signal wire from the vehicle speed sensor to the violet ( purple ) wire on the dash loom from the ecu ( its up under the glove box i think ) To wire the vehicle speed sensor just cut the purple wire and wire your new signal wire to the dash side of the loom to the speedo cluster, dont re join the purple wire again, just leave it.
Wow I have good memory, I think there is a diagram if you read this thread
