Project VH
Hi,
I have been trawling the site for weeks and have scrounged up as much info/pics as i can on doint this conversion.
There is most of the info around (cheers VK SL 3800) but most of the rest of it is scattered here there and everywhere.
My aim is to get all of the info as to what is required to do the conversion & what is required to be changed on the recipient vehicle for the conversion to work.
Mainly after write ups & pics on the difficult stuff, Like massaging the trans tunnel to fir the 4 speed auto (Is it required, What needs to be done)?
Electrical - (can i run the entire engine loom from the computer inc fuse boxes etc)
Tailshaft - Have heard MANY different stories. (have heard that you can use a vk EFI rear end spliced with the VN/VP front end without having to cut/chop/weld the tailshaft at all, is this accurate)
Diff, Apparently the VN/VP diffs will bolt straight in (Any mods required? Will the brake lines need to be re-routed etc?)
K-Frame - Is retaining the standard (VH) setup the best?
Steering - (Modifications required if you change the k-frame etc)
Fuel Tank - (Obviously an extra fuel line is required if your car is not EFI, How to run it ETC)
Please no V6 Conversion Bashing here.
I'm trying to make this the be all and end all thread for this. I will also be posting pics of my efforts too, So if you have any pics POST THEM UP!!!
I have done a V6 conversion to my VH and you seem to have already gotten a heap of help from the guys on here but if needed here is the stuff i have done could be of some help to ya also
Electrical - I gutted the whole VH loom from the car bar the few wires from the heater control, i replaced the VH loom with the whole loom from the series one VN V6 making it easier to hook the motor and auto etc up.
Tailshaft - I have keeped the original whole VH shaft and hope this may be ok yet to find out (someone else may beable to inform me if this could cause problems at all)
Diff - Also the original VH item with drum brakes, (am planning on updateing to a VN disc type down the track just have to work out the rims side of things as the VN diff is about one or two inch wider, have heard the hand brake cable needs to be changed too)
K - Frame - I went with the whole change over to VN, struts and all as they bolt up now dramas (saves on alt things from the V6 to fit in).
Steering - Went with the whole change to VN shaft with just altering the bracket to bolt under the dash and bolt up to the rack now being VN as well. (Steering seem to work correctly so far)
Fuel tank - Removed the VH item and swapped to a VN one with the replacing of the fuel lines to the motor with VL item as to keep the floor shape on the lines just had to remove the external pump on the feed line and sligthly alt path of line in the engine bay.
Also replaced the fuel filler neck to VN as well.
I also have some info on my forum page at "street commodores.com.au" if that helps good luck mate will be good to see some pics and the other feed back from the other guys on here as these forum page guys are a great help.
cheers
