weston
Holden VH V6 Commodore
- Apr 15, 2009
- 148
- 1
- 16
- VH Commodore
Project VH
So what is the plan you have for you VH sounds pretty much a similar job to what i have done but using VP parts. I found the easiest way to do this was to rip out the Motor, Trans, driveshaft, complete wiring looms front to back etc and swap over to the goods from the donar car.
Being a VP i think this is the last model that can swap the whole front end, struts k frame brakes and all that without a problem, i beleave that the VR onwards you would have to change bits to fit in the V6. With mine i swapped over the full wiring in the car to make it a piece of piss to plug up to the Engine and trans and saved the problem of working out the way around the dash cluster as i have gone with the VN cluster as well.
I also wanted to have the wipers on a seperate arm to the blinkers like the way the VR onwards have so i replaced the VH steering column to the VN this making the indicator switch a plug in job, the wipers took a little playing with as the wipers on the VN, VP is up near the cluster but from memory the plug in the original switch plugs straight to the VR/S arm now on the column.
Using the diagrams and tracing the different wires for the demister, hazards etc did give a few headaches but we got there, the biggest problem was from the VR/S headlight switch i used as without the use of another relay in the loom i had it all working but i had low beam on all the time even when it was switched off.
If you need help along the way let me know and ill try to help out where i can, feel free to look on the "street commodores" site forum pages under "project VH" i have a few pics there that may help.
