Post Vintage
- Mar 4, 2007
- 123
- 0
- 0
- Location
- The South
- VN V6 Manual
The car didnt start up this morning, and I have been having problems with it like that a fair bit. Spark there from the dizzy, and fuel fine... definately timing I think. Anyway, I got a guide from oldholden.com on how to do it, since most of my other cars have been really straight forward I thought id just rip out the dizzy and redo it 'properly'.
Retiming engine from scratch link from Oldholden.com
As I rotated the crank, Cylinder #1's inlet valve opens then closes and the guide says that at the end of the close the dizzy should be on TDC, so rotate the crank to 6btdc and then set the dizzy to fire Cyl#1.
The mark on the crank pulley however is totally out of line from this, and going either way from that mark while turning the crank doesnt do nothing to the inlet valve.
Tried this with the vacuum advance module plugged in and not... still nothing.
Running a 173 holden red engine w/ electronic ignition.
Edit: On the timing cover, there is TDC, and some major notch anti-clockwise to that, and about four notches clockwise with an R above them. I figure this was timing retard and the notch to the left of the TDC mark is something I have no idea.
