I should probably mention, that in my manual, the 3S-GE has recommended 178PSI and minimum is 142psi with no more than 14psi difference between cylinders. So my compression test wasn't that great. Dry test: 150, 150, 150, 145. Wet test: 160, 165, 160, 160.
Btw Hi Flow Reconditioning did the compression test and that's the figures they got. Said it was good. (I got the manual after he done the test)
Edit: I did a compression test before anyone else looked at the car. Think I had a faulty Tester (it was brand new tho, $50 (most expensive at supercheap)) and got ridiculous pressures. My Dry test 185, 190, 192, 192. Wet Test: 230, 260, 240, 250. (Put 1tablespoon of oil into each cylinder).
Edit: Near the beginning when the white smoke wasn't that bad. If revs were over 3000, you'd see black smoke coming out (according to my dad), I never really reved it over 3000 so I didn't notice it.
