TPMS showing low pressure FLH wheel. MY17 SSV SPORTSWAGON.
stooge
wa
Turbo Alpaca
You know a forum has turned to absolute garbage when there's 2 pages of people duscussing a flat tyre.. RIP
we know education has failed the world when you make comments like that :rolleyes:
Drawnnite
Obviously Unsensible
2000 Vs Ute
Might sound wierd, but is the valve cap on correctly?
Have the TPMS system on the VZ and a mate being a smart one put a different cap on for a giggle.
Driving home it started to alarm as a very slow leak turning to a flat, got to the servo to pump it up, found the flashing valve cap.
pumped it up, and took off that cap (must have just been able to touch/press the valve stem) and it was alright.
Just another potential reason for you.
HSV126
Briggs & Stratton
You do understand my comment was implying exactly that? Then with almost perfect timing you come along and manifest the perfect example of idiocy in which my tongue in cheek remark was based. Well done you deserve a treat
stooge
wa
Turbo Alpaca
the perfect example of idiocy was your first comment ;)
you had absolutely nothing to add to the thread so you decided to post a stupid remark that adds nothing to the thread apart from showing to the members that you are the village idiot, well done you deserve a scooby snack.
next time you should try and join the "duscussion" and "duscuss" relevant points based on the thread at hand instead of being a donut :D
  • Like
Reactions: NME
Skylarking
123
Downunder
Commodore Motorsport Edition
Don’t worry about it @stooge, he drives an EA Falcon :p
(tongue in cheek comment @Keesh so don’t get knickers in a knott)
NME
56
Rockingham
SS V Redline VF Series II Sportswagon
vc commodore
Like the Leyland Brothers
VC, VH and VY
Most screw/nail type punctures can be plugged, punctures from a bolt etc means damage is terminal.
No passenger tyre can be legally plugged.....If a tyre store does this, they can be liable for any damages the car causes if the tyre fails due to internal damage....
A tyre must be removed from the rim to be inspected for any signs of damage to the sidewall...Once it is deemed safe to repair, it must have a mushroom plug, which is a plat piece of rubber, with a tubular piece of rubber sticking up wards (it's shaped like a mushroom) fitted, so no moisture can enter the hole in the tyre, where a foreign object has entered...Moisture in a hole that has been created by a foreign object can cause the steel belts to rust, therefore weaken...
A bolt in a tyre doesn't mean the tyre is cactus.....It is quite common for tyres to be punctured by bolts....As long as the mushroom plug seals the hole correctly and there is no damage to the sidewall, internally or externally, the tyre can be repaired and placed back on the car...
So this information you have provided is false
Forg
Regal Peackock VF SS-V Redline Wagoon
Is this plug-illegality a South Australian thing?
I can’t find any rules for NSW that say it’s illegal OR legal, but the NSW RMS guideline on replacement wheels & tyres from 2019 says damaged tyres must be “replaced or repaired” (and I can’t think of other ways you can repair a tyre?) and there’s a Bob Jane T-Marts website page from 2019 that also talks about repairing tyres if it’s deemed possible (and a large chain like that would be very wary of saying/recommending something illegal).
HSV126
Briggs & Stratton
My comment was relevant.
TPMS tells OP his pessures low, OP attempts to correct pressure, pressure drops again.. OP's first instinct is to create a profile to ask people online who cant even see the tyre what the problem is rather than seeing one of a million tyre shops?
If I'm the village idiot for pointing that out then my comment is not only relevant its validated.
HSV126
Briggs & Stratton
Ill help you all out in regard to tyre repair. The centre 75% of the total tread can be repaired if the puncture will take the plug (mushroom plug from inside, not rope). In most cases the puncture is enlarged to accomodate the plug anyway so bolt, screw, nail its irrelevant as long as it can be opened up with and cleaned. The remaining section of the shoulder can not be repaired, (not to say people dont) Run flat tyres can not be repaired (again not to say people don't) Its always going to come down to the individual as to whether they feel it acceptable and safe to carry out a repair
