CRUSTIN
P-plater
- Nov 18, 2010
- 331
- 0
- 0
- Location
- Brisbane
- VZ S 175 Ute
firstly, mucking around with vcm suite is not going to change the timing of the cams, because theyre done with timing chains..... and it's not going to change the profile of the cam lobes either... so that's rubbish...
And secondly, you can't run a "heavily modified VE SV6 tune on your 175kw auto vz exec"... so whoever told you that just ripped you off... There are different components on an SV6 in the inlet manifold, and i beleive there are subtle cam and throttle control differences in the PCM that can't just be "transferred over". They also have a different gearbox to yours.
If the OP wants to try cams out, by all means go for it. it would be great for the community to get some feedback on what could very well be the most effective means of powering up an alloytec
Cam timing can be adjusted 50 degrees advance or retard by the computer. Its not hard to engineer.
